Early-Bird Benefits - Ends 31 Aug
Multi-Functional Fast Charging for Everyday Convenience
Charging with EcoFlow X-Stream Tech
With EcoFlow’s 1500W X-Stream AC input, DELTA 3 (1500) charges from 0-100% in only 90 minutes. Stay prepped for a power outage or take a last-minute camping trip.
100W Recharge in a Flash
Low on power before your commute or flight? This power bank recharges up to 50% in just 26 minutes—perfect for two full phone charges or a quick laptop top-up to last the day.
With 100W USB-C port or cable input:
– Recharge from 0% to 80% capacity (20,000mAh) in 53 minutes
– Recharge from 0% to 100% capacity (25,000mAh) in 80 minutes
Built-in Design, Ready When You Are
No more lost cables—the 100W built-in USB-C retractable and lanyard cables are always there, tucked neatly into the power bank’s sleek design, with a retractable mechanism that lets you access power in seconds.
Massive 25,000mAh Capacity in a Compact Size
90Wh air-travel-friendly*, while high-density cells maximise capacity in a travel-ready design.
– Charge a MacBook Pro 1 time, extending battery life by 24 hours
– Charge an iPhone 16 4.6 times, extending battery life by 115 hours
– Charge a Steam Deck 1.75 times, extending battery life by 10 hours
* Airline regulations vary by region and carrier. Please confirm battery restrictions with your airline before travel.
Advanced Protection, Maximum Performance
Protected by EcoFlow’s X-Guard
Features pro-grade battery technology found in electric car batteries. EcoFlow RAPID’s Battery Management System continuously monitors the charging process with quadruple protection to prevent overcharging, over-discharging, overheating, and short circuiting, ensuring safe and stable operation.
Smart TFT Screen with a Dynamic Display
Enhance your charging experience with an intelligent power display. You can view your real-time capacity, port power, battery health, temperature, charging cycles,emojis, and more. The crystal-clear TFT display screen lets you check your data at any angle, in any lighting condition.
Compatible with 99% of Daily-use Electronic Devices
Fits in anywhere you go.
Specs - EcoFlow RAPID Power Bank (25,000mAh, 170W, 100W Built-In and Retractable Cables)
Total Cell Capacity
25000mAh
25000mAhBattery Capacity
14500mAh (5V/3A discharge)
157 × 53.8 × 48.8 mm, dimensional tolerance ± 0.5 mm
580 g (approx.)
Appearance
Housing material: black, silver grey
Integrated built-in cable material: braided
Ternary Lithium
300 cycles to 80% capacity
Total Output Ports
1 USB-C port: 100W
1 Retractable cable (USB-C port): 100W
1 Built-in cable (USB-C port): 100W
1 USB-A port: 18W
Total 170W
Built-In Cable Output
Bulit-in C Cable (two-way fast charging 100W): 26 cm
Built-in C retractable cable (two-way fast charging 100W): 67 cm
1 USB-A port: 18W
1 USB-C port: 100W
Input
100W
USB-C Recharge
Multi-port input is not supported, the maximum power of a single port input can reach 100W.
USB-C port/built-in cable/retractable cable: 100W input
USB-A Recharge
APP
Not compatible
Screen
TFT
Drop-resistant
1 m
Fireproof
Housing V0 Fireproof
2 Years
Charge Temperature
20℃–30℃ (68℉–86℉)
Discharge Temperature
0℃–45℃ (32℉–113℉)
Storage Temperature
–10℃–45℃ (14℉–113℉)
Compatible devices are laptops, phones, tablets, headphones, smartwatches, game consoles and other devices with USB-C ports such as MacBook Pro/Air, iPhone,iPad, Dell XPS and Samsung Galaxy.
BC1.2/Apple2.4A/QC3.0/FCP/SCP/AFC/UFCS/PD3.0/PPS
To ensure fast and stable charging and discharging performance when using the power bank, we recommend the following.
1. Choose the Right Charger:
Use a charger that supports fast charging protocols and has a high output power (such as PD 65W or 100W). Avoid using low-power chargers (such as 5V/1A).
2. Use a Good Charging Cable:
Select original or high-quality fast charging cables. Keep connectors clean and secure, and avoid excessively long cables.
3. Device Compatibility:
Make sure the connected devices support fast charging protocols; otherwise, fast charging will not be achieved.
The power bank retains over 80% of its battery capacity after 300 charge cycles. It supports charging and discharging at altitudes below 3000 meters and in environments with temperatures between 0°C and 40°C. If not used for an extended period, it is recommended to store the power bank in an environment between -20°C and 40°C and to recharge it at least once every three months.
Yes, according to regulations by the International Civil Aviation Organization (ICAO) and most airlines, carrying a power bank with a capacity under 100Wh is allowed. The RAPID Pro, with a capacity of 25000mAh (90Wh), meets this requirement and can be carried on board without concern.
Nominal capacity refers to the total capacity of the battery cells inside the power bank, while rated capacity refers to the actual amount of power the power bank can deliver under standard output conditions (such as 5V/3A). Nominal capacity is a theoretical value, whereas rated capacity accounts for energy conversion efficiency, circuit losses, and other factors, and is therefore lower than the nominal capacity.
Yes. When charging through the USB-C port, output is supported from another USB-C port or one USB-C + USB-A port simultaneously, but not from two USB-C ports simultaneously.
Campaign Duration
The EcoFlow Power Bank Launch Campaign runs from 24 June 2025, 9 AM (CET) to 1 September 2025, 9 AM (CET).
EcoFlow reserves the right to modify or extend the campaign period at its sole discretion without prior notice.
Eligibility
The campaign is open to European residents aged 18 and above as of 24 June 2025, 9 AM (CET).
Availability
This campaign, including promotions, gifts, and discounts, is available exclusively on eu.ecoflow.com. Purchases made on other platforms or websites are not eligible for campaign offers.
Campaign Details
Launch Discount
1. From 24 June, 9 AM (CET) to 1 August 2025, 9 AM (CET), selected EcoFlow Power Bank products will be available with up to 18% off as part of the launch campaign.
2. The discount is applied directly to the product page price.
3. This discount can be combined with other eligible promotions or coupons unless otherwise specified.
Bonus EcoCredits
1. From 24 June, 9 AM (CET) to 1 September 2025, 9 AM (CET), users will earn bonus EcoCredits for every €1 spent on eligible Power Bank products:
– Standard Members: 3× EcoCredits
– PLUS Members: 4× EcoCredits
2. Credits are calculated based on the final purchase price and will be issued 7 days after delivery, provided no returns or cancellations occur.
Please Note:
1. Customers must log into their EcoFlow account using the same email used to place the order.
2. If a customer hasn’t registered yet, they can sign up for a free account.
3. If a return is initiated, the awarded EcoCredits will be withdrawn.
4. For more infomation about EcoCredits, please refer to the page https://www.ecoflow.com/eu/ecocredits.
Power Bank User Coupon
1. From 24 June, 9 AM (CET) to 1 September 2025, 9 AM (CET) Customers who previously purchased a RAPID power bank or an eligible third-party power bank can receive a one-time 10% discount to use on Power Bank products.
2. To claim the coupon, customers must submit their emails and either a proof of purchase or a photo of the product. The coupon will be sent via email and can be used for a limited time. By providing your email address and subscribing, you agree to the Email Marketing Terms & Conditions, subscribe to EcoFlow marketing emails, and consent to receive updates from EcoFlow.
3. Coupon usage is subject to product availability and may not be combined with other coupons or sitewide discounts unless otherwise specified.
4. EcoFlow reserves the right to verify submissions and deny eligibility if fraudulent or incomplete information is provided.
5. The coupon is only valid for a limited time stated, while stock lasts.
Power Bank Accessory Discount
1. When customers purchase any EcoFlow Power Bank, they can also purchase eligible Power Bank accessories at discounted prices.
2. The accessory discount is automatically applied in the shopping cart when at least one Power Bank and one or more qualifying accessories are added to the same order.
3. This discount can be combined with other applicable discounts or promotions unless otherwise stated.
4. Offer valid while accessory stock lasts.
General
1. If you encounter any problems during the promotion, please contact support.eu@ecoflow.com for assistance.
2. To the extent permitted by applicable law, we may decide to modify these rules or cancel the promotion at any time. If there is any fraud or abuse related to the promotion, we reserve the right to exclude any customer from the promotion.
3. Participants in the Sale agree to be bound by the terms and conditions set forth herein and understand that EcoFlow’s decisions are final and binding. No correspondence or appeals will be entertained. EcoFlow reserves the right to make the final and ultimate interpretation of this campaign.
4. All orders must comply with EcoFlow’s purchase agreement and return policy during the sale promotion.
5. The sale promotion does not apply to wholesale or distributor orders.
6. Any unauthorised or fraudulent behaviour will result in the disqualification of participants.
7. Participants must comply with all applicable laws and regulations.
8. EcoFlow reserves the right to stop, cancel, or change the promotion at any time during the promotion. Any changes will be announced on the EcoFlow official website.
9. All prizes in this promotion are limited in quantity and are available on a first-come, first-served basis. Any matters not covered herein will be handled according to EcoFlow’s final interpretation.
10. EcoFlow will assume no responsibility for late entries, which may occur for any reason, including but not limited to network transmission failure.
11. EcoFlow will not be responsible for any direct or indirect losses or damages incurred by any party, including the participants, in connection with or arising from acts or omissions or any way related to this campaign.
12. Participants agree to release and discharge EcoFlow from any liabilities and claims, including breach of contract, tort, negligence, or any other cause of action at law or equity, arising out of or in any way connected to this campaign or the participant’s entry into the campaign.
13. All products and free gifts (if applicable) related to this promotion will be shipped in accordance with EcoFlow’s Shipping Policy (https://eu.ecoflow.com/policies/shipping-policy)
14. There may be instances where EcoFlow is unable to accept or must cancel certain orders. EcoFlow reserves the right, at its sole discretion, to refuse or cancel any order for any reason. In such cases, EcoFlow is not responsible for any inaccuracies, errors, or potential consequences arising from the cancellation.
