The most powerful and compact portable AC
that can be used anywhere, anytime
"Best Portable Air Conditioning
Device at CES 2023"
——by MakeUseOf
Right Temp. Right Now.
RVs
Trucks
Off-grid houses
Outdoors
Tents
Boats
RVs
Trucks
Off-grid houses
Outdoors
Tents
Boats
Fastest cooling and heating
The world's first wireless portable AC with a heater.
EcoFlow's tailor-made compressor enables WAVE 2 to provide 5100 BTUs of cooling
and 6100 BTUs of heating. Prepare for ultimate comfort with WAVE 2!
* Drop 10℃ from 30℃ for 10m³ in 5 min with 5100 BTUs of cooling,and raise 10℃ from 20℃ in 5 minutes for 10m³ with 6100 BTUs of heating in optimal running performance.
Installation-free! Fits anywhere
The perfect air conditioner for any compact space! It is extremely simple to use, requiring no installation or drainage*. There are air duct adapters
to fit any space. Enjoy the convenience of cooling and heating without any fuss.
* No drainage is needed in cooling mode when humidity is below 70%, but it is still needed in heating mode.
Peaceful snooze, quiet & long
With EcoFlow's advanced software algorithm, the WAVE 2 offers multiple modes and app control. It runs
quietly (44 dB) in Sleep Mode and up to 8 hours in Eco Mode. Experience longer-lasting comfort in your
tent, RV, or home with its powerful and portable design.
Eco Mode (8 hours of runtime)
Sleep Mode (As quiet as 44dB)
Using R290: A greener way to beat the heat.
At EcoFlow, eco-friendliness meets ultimate comfort. WAVE 2 uses R290, a natural refrigerant
that's clean, green, and perfect for a relaxing cooling experience. With lower global warming
potential and no ozone emissions, it's the ideal way to stay cool and comfortable compared
to traditional refrigerants while reducing your carbon footprint.
Charge fast, at home or on the go
WAVE 2—the ultimate air conditioner and heater with an optional swappable battery! Charge it fast with
AC, solar, a car, or power stations. Enjoy cool or warm air
anytime, anywhere, with the flexibility of multiple charging options.
AC
Power Station
Solar
Car
AC
Power Station
Solar
Car
WAVE 2 is just the start. Pair with an EcoFlow DELTA 2 / DELTA Max or their extra batteries and get
an astonishing 7-14hr run time in Eco Mode. Compared to using other portable power stations,
it's 28% more efficient. You can also use any portable power station with a 820W input to charge
your WAVE 2.
Powerful portability, according to your
needs.
It’s the most powerful air conditioner of its size by a long shot. Carry it anywhere and
attach ducts for directed, efficient cooling. Ideal for tents, RV windows, or placing
your unit at a distance.
Air outlet duct (single)
Exhaust air ducts (dual)
Exhaust air ducts (dual) with window vent board
Or accessory-free anywhere
What’s in the box
EcoFlow WAVE 2
Exhaust duct E
Exhaust duct
adapter cover B
Exhaust duct D
Window vent board
Exhaust duct adapter cover C
Winder and Drain
pipe
Exhaust duct
adapter cover A
Safety Instructions, Quick Start Guide,
and Warranty Card
AC Input
100/240V, 50/60Hz, 820W Max
Solar Charging Input
11-60V, 13A, 400W Max
Car Charging Input
96W/192W (12/24V, 8A Max)
Add-On Battery Power
700W Max
Approximately 14.5 kg
518 × 297 × 336 mm
Bluetooth
Wi-Fi
This product supports 2.4G Wi-Fi only
Noise Level
44-56dB
Refrigerant/Amount
R290/130g
No-Drain Function
Supported (in cooling state)
Cooling Area
≤ 10 ㎡ / 107.6 ft²
IP Rating
IPX4
Rated Cooling Input Power (AC/DC)
550W/495W
Max. Cooling Power (AC/DC)
820W/700W
Cooling Capacity
1500W/5100BTU
600W/540W
Max. Heating Power (AC/DC)
820W/700W
Heating Capacity
1800W / 6100BTU
